LabWindows/CVI
create shortcut to folder
Accepted by topic author JGS
To be honest, I am not sure what dependency CLSID_FolderShortcut has on Internet Explorer. I was able to just define the  _WIN32_IE before including the header file like:
#define _WIN32_IE 0x0500
or you can add it to the Compiler Defines in Build Options like:
/D_WIN32_IE=0x0501
Here is an MSDN article that explains what the value of this definition might be:
http://msdn.microsoft.com/en-us/library/aa383745%28v=vs.85%29.aspx
Even with this, I can run the code, but I get an error using CLSID_FolderShortcut. I have tried to get more information about CLSID_FolderShortcut and how to use it, but there are not many resources provided by Microsoft that I could find. Maybe someone here has some insight?
However, I was able produce a folder shortcut using CLSID_ShellLink. Use the exact same code as you did for a file, but specify the path to a directory instead of a file.
Message 11 of 12
(1,085 Views)
It works ! Thank you all.
The CVI version works when ignoring the MSDN comment about CLSID_FolderShortcut and therefore avoiding the conditional _WIN32_IE definition. And I replaced the uuid.lib in ...\CVI2010\sdk\lib\msvc64. I have a (never finished) working code.
I also tried the VB proposed example in an Excel macro. This works beautiful and I archived it for some future alternative.
Regards, Jos
Message 12 of 12
(1,074 Views)
