LabWindows/CVI
creating a log file box or window with all your error handling
Instead of passing the description string to MessagePopup you can simply add it to a textbox, listbox or other UI control or WriteLine it to a file.
If you use a
Message 11 of 31
(2,062 Views)
yeah im getting to many errors with your code, im going to fixthat later, im going to work on the log window
so the writeline function is basically doing what?
Message 12 of 31
(2,029 Views)
It's an instructions from the Formatting and I/O Library to write to a file. Look in the online help for it. Alternatively you could use fwrite or fputs.
Message 13 of 31
(2,028 Views)
so basically i use the writeline,its going to send my strings to an log window?
Message 14 of 31
(2,027 Views)
As I said earlier, it's an instructions from the Formatting and I/O Library to write to a file
Depending on which control you are using as a log window, it will have different way of writing to it.
Message 15 of 31
(2,027 Views)
i need a lil help trying to finish this off i want write this errors as well to the text file.
void DisplayRS232Error (int bytes_sent,int bytes_read)
    File *f1=0;
    f1 = fopen("RECORD_OF_ERRORS.txt", "w");
    char ErrorMessage[200];
    switch (RS232Error)
        default :
            if (RS232Error < 0)
                Fmt (ErrorMessage, "%s<RS232 error number %i", RS232Error);
                MessagePopup ("RS232 Message", ErrorMessage);
            break;
        case 0  :
            MessagePopup ("RS232 Message", "No errors.");
            break;
        case -2 :
            Fmt (ErrorMessage, "%s", "Invalid port number (must be in the "
                                     "range 1 to 8).");
            break;
        case -3 :
            Fmt (ErrorMessage, "%s", "No port is open.\n"
                 "Check COM Port setting in Configure.");
            break;
        case -99 :
            Fmt (ErrorMessage, "%s", "Timeout error.\n\n"
                 "Either increase timeout value,\n"
                 "       check COM Port setting, or\n"
                 "       check device.");
            break;
Message 16 of 31
(1,992 Views)
 Undefined symbol '_RECORD_OF_ERRORS' referenced in "RS-33_CHILLER.c".
im getting this error when i try it this way.
    FILE *f1=0;
    size_t str_length = 0;
    switch (RS232Error)
        default :
            if (RS232Error < 0)
                WriteStringToFile (f1, ErrorMessage);
            break;
        case 0  :
            break;
        case -2 :
                                     "range 1 to 8).");
            break;
        case -3 :
            break;
        case -99 :
                 "       check device.");
            break;
fclose(f1);
Message 17 of 31
(1,994 Views)
nevermind i found why i got that error, is this going to work how im doing it, any suggestions.
    FILE *f1=0;
    switch (RS232Error)
        default :
            if (RS232Error < 0)
            break;
        case 0  :
            break;
        case -2 :
                                     "range 1 to 8).");
            break;
        case -3 :
            break;
        case -99 :
                 "       check device.");
            break;
Message 18 of 31
(1,994 Views)
many suggestion: what you wrote is never going to do what you want.
1. i don't see the point of declaring bytes_sent and bytes_read as arguments to the DisplayRS232Error() function: those  values are never used in the body of the function.
2.  where is RS232Error declared ? it seems like it is a global variable. it would be much more correct to pass it as an argument (that's about the only value on which this function depends)
3. you open the log file at the beginning of the function. that's not efficient, the file will be opened each time there is an RS232 error. it would be better to open the file once at the beginning of the program and close it properly at the end.
4. you open the file with a "w" mode: read the documentation for the fopen() function. the file will be erased each time you call the DisplayRS232Error(), thus losing any previous error. i am pretty sure you want to use mode "w+" which append to the file if it already exists.
5. you open the log file but you do never close it ! remember to always free the resource you are using, files are no exception.
beside this, i will add:
6. a log is useless without other informations, like the date and time an error occured.
7. do you ever test your code before posting ? point 4 is critical, and running your software only 2 times would have showed this problem. take the time to review your code, compile it, test it, debug it, and try to correct as much problems as you can by yourself (it is much more rewarding) before posting another question. you could have avoided your last 2 posts if you had done your job correctly.
Message 19 of 31
(1,993 Views)
right now im trying something out , basically trying to see if  i can all my message pop ups in the text file, then im going to go back and format them with the date and time etc............
so if it take the FILE * f1 out the function and put itin my main i get undeclared errors because im using writestringtofile.
so how would i do this logic. and yes im stepping through it now. let me try something else  i got a mind block at the moment.
Message 20 of 31
(1,987 Views)
