LabWindows/CVI
custom thread pool function return values?
Is it not possible to return custom values from a thread pool function?
I'm using CmtGetThreadPoolFunctionAttribute to get the thread pool function return value, but it seems to only send me 0 (pass) and -1 (fail).  My thread function though can return several custom integer value codes depending on what exactly failed.
Is there a way?
(1,400 Views)
Argh.  Disregard.  This isn't true.  I had a bug in my test code.  The thread pool function will indeed return any value you want it to into the ATTR_TP_FUNCTION_RETURN_VALUE attribute.  That's super helpful for parsing failure codes!
(1,397 Views)
