LabWindows/CVI
custom version number for target settings
Is there a way to input the version settings at compile time, outside of the Version Info dialog of Target Settings?
What I'm really after is this: I would like to append the SVN revision of a project to its compiled binary.  Something like:
3.1.0.3167
...where 3167 is the SVN revision, the other numbers are specific to CVI and this build.
I see in the version dialog where we have access to built-in macros and modifiers for the parts of this version system.  Yet, I'm not seeing a way to have a pre-compiler script send values directly to the version number before it's built.
Here's a look at my project's version setup:
And the corresponding EXE that was built has this file properties:
You'll notice that the "File Version" is not the second file version (not sure what that one's for), but the first.
I would love to insert my SVN revision so that I can track back problems in production to a specific revision to recreate the issue and debug.
(2,893 Views)
Hi ElectroLund,
You try to use CVI's command line interface to build since it allows specifying product and file versions.
Because it's a command line application, you may be able to create a batch file that reads the version from SVN and pass it to CVI's command line interface.
(2,845 Views)
Would it be possible to send command line parameters into CVI's build steps window?  I'm thinking of using the "fileVersion" switch:
I'm not opposed to doing all this from command line, but I'd prefer to be able to launch that process from CVI somehow, with the project loaded.
(2,506 Views)
