LabWindows/CVI
cvi 2010 menu preventing callback execution
Hi y'all
i am using cvi 2010 and i am having an issue with the menu selection field not allowing the execution of the serial callback function. When you hover over the menu  without selecting it, its ok, if you click on the menu and during the time you are making a selection  the callback execution never gets called.
the callback also seems to get inturupted by user input events ie.. selecting a numerical box, command boxs etc
This happens in both bebugging and the release executable.
is this a known issue?
(3,169 Views)
unless someone knows a different solution this is what i dug up
http://digital.ni.com/public.nsf/allkb/34D1A6C408FAF9BE86256C710080CCA7
(3,164 Views)
