LabWindows/CVI
cvi 2012 install directory
Hi!
The building of a distribution is really easy with cvi2012. But there are some problems.
Here is my problem: the destination directory for my program is always ..\Install<ProjName>. The in the edit installer -> files tab specified directory is a different one. How can I change the directory???
Darius.
(3,031 Views)
hi darius,
i'm not shure if i understand your question right.I attached you two screenshots of the installer window.
In the files tab you can create the directory, you would like to have on the target pc. The section on top is your developement pc and you can choose which file you want to include in your insaller. The section below is the virtual target pc and you can decide the structure of the directory of your target.
If you want to add a folder into your directory you can do a right click in the section of your target, see in picture 2
If I missunderstood your question, please add a screenshot and a detailed describtion.
Regards
Michael F.
(2,995 Views)
