LabWindows/CVI
(cvi 7.1 + NI-motion 7.2) installation and other problem
I'm using cvi 7.1 with NI-motion 7.2.
After installation of NI-motion 7.2, I cannot find NI-motion library in CVI menu.
So, to use flex motion library, I added NI-motion library manually in Library>Customize>user library menus.
But in this time pop-up help for NI-motion library does not work properly.
For example, if I right-click 'flex_load_rpsps (u8Board, u8Axis, NIMC_BOTH, f64Rpsps, 0xFF)' in my codes,
cvi says 'could not launch c:\program files\national instruments\cvi71\bin\ni-motion labwindows - cvi reference.chm'
But definitely the exact help file exsists at that correct position!
Finally, I think Ni-motion 7.2 has some promblems with labwindows 7.1.
(3,065 Views)
Hi wchegal -
It appears that the NI-Motion 7.2 driver help doesn't correctly integrate with CVI 7.x or 8.x.  I've notified the development team, and we'll fix it for the next driver update.  I apologize for the bug, but I also want to thank you for letting us know about it.
In the meantime, you can still view help for your Motion functions in the NI-Motion C Reference Help.  You can find this file in Start»Programs»National Instruments»NI-Motion»Documentation.
David Staab, CLA
Staff Systems Engineer
(3,049 Views)
