LabWindows/CVI
cvi 9.0.1 runtime install error
I am trying to distribute a CVI 9.0.1 app onto an XP machine and it fails during CVI RTE installation.
The NI LabWindows/CVI 9.0.1 Run-Time Engine installation has failed with the following error.
Error 1935.  An error occurrred during installation of assembly 'National Instruments.CVI.Reflector,Version="9.0.375.0",Culture="neutrasl",PublicKeyToken="F83B88E0AAF4FB33:.  please refer to Help and Support fro more information.  HRESULT: 0x8002802F.
Any idea what this is about?  An eval version of CVI 8.5 was on the target but I've removed it.
Menchar
(3,953 Views)
I removed everything on the target that was NI.    Same problem.
Went into system32 directory and removed the NI dll's that were left after un-installing everything (!) and no difference.
I tried installing the CVI 9.0.1 RTE from a downloaded CVIRTE only, and same weird error.
Target is Windows XP Sp3  quad 2 GHz Xeon with 3GB of memory.
This has me dead in the water.
Menchar
(3,949 Views)
Menchar:
If you search this forum for 1935, you'll find a couple of posts related to .NET components, including this knowledgebase article.
http://digital.ni.com/public.nsf/websearch/98420F376B25F45B862570DD00615F09?OpenDocument
(3,924 Views)
See also this thread
(3,914 Views)
Thanks, installing .NET 2.0 SP2 solved the problem.
The IVI always seems to be a hassle - even though I never use it.
Menchar
(3,902 Views)
