LabWindows/CVI
cvi Internet toolkit usage
Can use the 3rd web server (e.g. Apache or IIS)to replace the build in web server in LabWindows/CVI ?
David
(3,165 Views)
Hi David,
I don't believe that you can change the webserver that's associated with the CVI Internet Toolkit. The reason is that any remote front panel functionality would not work with other webservers. In addition, the functions all require a handle to the CVI webserver, which is obtained by calling StartWebServer. This function always starts the CVI webserver, and doesn't give you access to any other.
Jeremy L.
(3,153 Views)
