LabWindows/CVI
cvi SetTableCellRangeAttribute
I  am using cvi 8.0 to create a table in the uir file, the table default attribute is INDICATOR. when the application launched, dynamically insert a row, then want to edit the cell's data. I use "SetTableRowAttribute(panelHandle, DEVTAB_DEVTABLE, devTableRow+1, ATTR_CELL_MODE, VAL_HOT); " hope can make the row change the run mode from INDICATOR to HOT, so that i can edit it, but whatever this behavior can not appear. please advise how to realize the function. Thanks.
David
(3,655 Views)
And also use "SetTableCellRangeAttribute(panelHandle, DEVTAB_DEVTABLE, MakeRect(devTableRow+1, 1, 1, 5), ATTR_CELL_MODE, VAL_HOT); " to try it, but not any response.
David
(3,655 Views)
David, despite the state of individual cells, you cannot operate on a table if the control itself is in INDICATOR mode. Check that the table is in normal or hot mode and your new cells should be editable.
(3,650 Views)
