LabWindows/CVI
cvi vista enterprise
Hi all,
anyone can answer me for this error. I use development PC with WinVista Enterprise and Labwindows/cvi 9.0 as debugger. While another pc with Winwdos XP where I have installed application for to debugee. Now, after set all need value of IP address, either debugger PC and debugee, start Remote Debugging Configuration and start application on target PC and I receive cvi message error on PC debugger: "The labwindows/cvi run-time engine on the target is more recent than your labwindows/cvi environment. You have to upgrade you cvi environment if you want ....."
Note that I installed cvi run-time engine on host and target with the same version number. Anyone help me, please.
Thanks to all.
Message 1 of 1
(2,851 Views)
