LabWindows/CVI
cwgraph clear data
Hi folks!
I wrote this code in order to clear all plot data in my cwbraph object.
It seems does not working properly. Is there something wrong?
    CAObjHandle ObjHandle;        // Handle for activeX control
    GetObjHandleFromActiveXCtrl (panel, control, &ObjHandle);
    CWUIControlsLib__DCWGraphClearData(ObjHandle, NULL);
    CA_DiscardObjHandle(ObjHandle);
Thank you in advance.
(4,105 Views)
Hi Oliveira,
The code looks okay to me... How are you plotting the data in the first place?
This is what mine looks like, where:
PANEL_CWGRAPH is the constant name for my CWGraph
int CVICALLBACK ButtonPlot (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 VARIANT myVariant;
 double values[5] = {1,3,2,5,4};
 CA_VariantSet1DArray (&myVariant, CAVT_DOUBLE, 5, values);
 switch (event)
  case EVENT_COMMIT:
   GetObjHandleFromActiveXCtrl (panelHandle, PANEL_CWGRAPH, &ObjHandle);
   CWUIControlsLib__DCWGraphPlotY (ObjHandle, NULL, myVariant, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL);
   break;
  case EVENT_RIGHT_CLICK:
   break;
 return 0;
int CVICALLBACK ButtonClear (int panel, int control, int event,
 switch (event)
  case EVENT_COMMIT:
   break;
   break;
 return 0;
Jervin Justin
NI TestStand Product Manager
(4,082 Views)
Hi Jervin!
I plotted the graph using this command:
CWUIControlsLib__DCWGraphChartXvsY( p_objActiveXHandle, NULL, CA_VariantDouble (p_dblTimeToPlot), m_varDataToPlotY, CA_VariantBool(0) );
This command is in while loop and when the user clicks on one button I need to restart the graph. I got the click event, but when it is executed the clear command, nothing apparently occurs.
Regards.
(4,076 Views)
I use the refresh command and now it works properly.
Thank you for your help.
Message Edited by Oliveira on 04-04-2008 11:45 AM
(4,070 Views)
