LabWindows/CVI
cwnumedit to integer
How Do i convert a cwnumedit variable to an integer?
Sorry if this is already posted and thanks for the help in advance.
(2,975 Views)
Hello surferboy,
If you are try to use the CWNumEdit ActiveX control, you should do the following steps:
1. Get a handle to the ActiveX control.
GetObjHandleFromActiveXCtrl (panelHandle, PANEL_CWNUMEDIT, &numEditCtrl);
2. Get the value of the NumEdit control.
CWUIControlsLib__DCWNumEditGet_Value (numEditCtrl, NULL, &variantval);
3. Convert the variant into an integer.
CA_VariantConvertToType (&variantval, CAVT_INT, &intval);
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(2,962 Views)
