LabWindows/CVI
cycle through string box?
I want to read serialnumbers[char] in an Array[20]. Therefore I use a StringBox (I have no idea if that is the right way to do that!). I want to read the serialnumbers with a barcodereader. This reader acts like a normal keyboard. My question is now: How do I automaticlly cycle that after the first string is read into the stringbox, I can read the next string without hitting a butten? The barcodereader can generate an Enter or an linefeed, what ever makes an event for LabWindows.
(3,315 Views)
I'm not sure about this particular barcodereader that you are using, but if it does generate keystrokes just like a keyboard, this would be a perfect way to programmatically interact with your textbox in CVI. For instance, if you set up a callback like the following, you can wait for a key to be pressed when the textbox is selected and check to see if it is the enter key:
int CVICALLBACK TextBoxCB (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event) {
case EVENT_KEYPRESS:
if (eventData1 == VAL_ENTER_VKEY) {
// Do textbox manipulation here
break;
return 0;
Check out the description of the EVENT_KEYPRES
S event and the constants defined in the user interface library for the various different key codes within the LabWindows/CVI Online help.
Jason F.
www.ni.com/ask
(3,315 Views)
