LabWindows/CVI
d
Already answered to this question: read my previous post...
Message 21 of 63
(2,598 Views)
Ini_Readfromfile has to be before any ini writing function to append. so that we are on the same page its like a log file, im keeping track of everything
Message 22 of 63
(2,590 Views)
Thanks Roberto,Learning so much from you guys this is year of me being more libraries like never before and more functions
through last three years of coding.
Message 23 of 63
(2,591 Views)
Im checking to see if I handle the errorchecking right for the Ini_GetStringCopy  ?A little assistance?
int Boresight_Command(double  *dAZposX,double *dELposY)
    int error=0;
    char *sErrorMsg1=0;
    char sAZposX[100]={0};
    char sELposY[100]={0};
    char sCrtCommand[256]={0};
    char sDirPath[BUF_LEN_FOR_DIRECTORY];
    IniText iIniTextHandle=0; // Handle for the text file.
    char sPathName[BUF_LEN_FOR_DIRECTORY];
    GetProjectDir(sDirPath);
    MakePathname(sDirPath,KEY_TEXT_FILE,sPathName);
    //Verify if there is enough memory
    nullChk(iIniTextHandle=Ini_New (0));
    //Verify if file exist on disk
    error=FileExists(sPathName,0);
    if(error<=VI_SUCCESS)
       Terminate_Executable();
       return FAILURE;
    errChk(Ini_ReadFromFile (iIniTextHandle,sPathName));
    errChk(Ini_GetStringCopy(iIniTextHandle,g_sOperatorID, "OperatorID", //////////////////////////////I wanted to do a error check , did I do it right?
                           g_sOperatorID));
    errChk(Ini_GetDouble(iIniTextHandle,g_sSkrSerialNumberk,X_OFFSET_POS,
                         dAZposX));
    errChk(Ini_GetDouble(iIniTextHandle,g_sSkrSerialNumberk,Y_OFFSET_POS,
                         dELposY));
    Fmt(sAZposX,"%f",*dAZposX);
    sprintf(sCrtCommand,"SERVO, WRITE, 098000034, %s",sAZposX);
    Send_SERVO_Command(sCrtCommand);
    Fmt(sELposY,"%f",*dELposY);
    sprintf(sCrtCommand,"SERVO, WRITE, 098000038, %s",sELposY);
    Error:
    if(iIniTextHandle)
       //Cleaning memory
       Ini_Dispose (iIniTextHandle);
       //Cleaning memory
       free (g_sOperatorID);/////////////////////////////////// did i free in the right spot? im using the Ini_GetStringCopy
    if(error < VI_SUCCESS)
       sErrorMsg1 = GetGeneralErrorString (error);
       MessagePopup ("ERROR", sErrorMsg1);
    return error;
Message 24 of 63
(2,566 Views)
Sorry I left out my Casting of a pointer to pointer on my char variable in Ini_GetStringCopy
    int error=0;
    char *sErrorMsg1=0;
       return FAILURE;
                           g_sOperatorID));
                         dAZposX));
                         dELposY));
    Error:
    if(iIniTextHandle)
       //Cleaning memory
       //Cleaning memory
    return error;
Message 25 of 63
(2,565 Views)
Also guys while stepping through my code, i got non runtime fatal error from this
    g_sOperatorID = calloc( BUF_LEN, sizeof(char) );////////
    int error=0;
    char *sErrorMsg1=0;
       return FAILURE;
                           (char**)g_sOperatorID));
    g_sOperatorID = calloc( BUF_LEN, sizeof(char) );//////////////////////this is where i get the error
                         dAZposX));
                         dELposY));
    Error:
    if(iIniTextHandle)
       //Cleaning memory
       //Cleaning memory
    return error;
Message 26 of 63
(2,566 Views)
the error is  621, 53   Array assignments are illegal.
                   621, 53   Lvalue required.
Message 27 of 63
(2,565 Views)
Well, a couple of things are not fully clear to me:
  1. There is no evidence as to how g_sOperatorID is defined, so I won't argue anything about that. The 'g' prefix makes me assume it is a global variable but I don't understand why using a global variable while you could use a local one (it is dimensioned, used and freed in the same callback): try using a local string
           char sOperatorID[BUF_LEN];
    In case you want to actually store the string read in a global variable, DO NOT free it at the end of the callback!
  2. In any case, you must allocate the string BEFORE using it in Ini_GetStringCopy ()
  3. You are using the same variable both for Section Name and Buffer parameters: what's the meaning of that????? If you do not pass a proper value for Section Name parameter you are likely to read nothing from the IniText object!
Message Edited by Roberto Bozzolo on 11-25-2009 03:03 PM
Message 28 of 63
(2,560 Views)
well the reason Im naming it as a global is because  I want to remember where I am, Im using that global in many places through the source file
its define as g_sOperatorID[BUF_LEN];
Message 29 of 63
(2,555 Views)
also can you explain this?""it is dimensioned, used and freed in the same callback""
Message 30 of 63
(2,555 Views)
