LabWindows/CVI
d
    errChk(Ini_GetStringIntoBuffer (IniTextHandle, g_sOperatorID, "OperatorID",
                          g_sOperatorID2, BUF_LEN));
     if (error == 0) {
          error = ToolErr_MissingItem;      // defined in toolbox.h
          goto Error;
okay when I step through , the error value give me 1, which mean that the string is found.
which when I got to my log file , the string is not there or step through the this line.
which string the check is currently for ? is this for the second parameter  or the 4th parameter?
because the section is pull, but the fourth parameter is not there, it gives ""
Message 41 of 63
(1,571 Views)
The second parameter (Section Name) is passed to the function. The fourth is returned from the function.
Ini_GetStringIntoBuffer does nothing on Section Name string. If "OperatorID" item item is found in section Section name, its value is returned in g_sOperatorID2. If the item is an empty string (i.e. OperatorID ="") the string will be empty, otherwise it will show the chacters to the right of the equal sign. That's how IniFIle instrument works.
While stepping through the code, is there antything in g_sOperatorID2?
How is defined your LOG_FILE function?
Message 42 of 63
(1,567 Views)
right nothing is in that parameter at all, so its suppose to return a error, but instead it saids 1, when i go to the file it just saids ""
do you know y is that?
Message 43 of 63
(1,565 Views)
  • Can you show us the ini file?
  • Are you passing the name of an existing section in g_sOperatorID?
  • Can you try hardcoding section name with a fixed string like item name and see if it reads correctly?
  • Are other values read correctly from the ini file?
  • Can you post here a small sample project with only reading function and LOG_FILE function?
Message 44 of 63
(1,518 Views)
Message 45 of 63
(1,516 Views)
this is my logic before the boresight command function call, where im getting the operator id at first
int Calculate_Off_Set_Centroid_Point( double dSameXpositionValue,
                                      double dSameYpositionValue,
                                      FRAMEDETAILS FrameSize)
    int iHalfOfFrameWidth=0;
    int iHalfOfFrameHeight=0;
    int iMultiplier=0;
    int iBufSize=1000;
    int    iStatus    =SUCCESS;
    int        error = 0;
    unsigned int uiNameSize;
    double dOffSetXposition=0;
    double dOffSetYposition=0;
    char sUsername[1000]={0};
    char szStringk[1000] = "";
    char *sErrorMsg1=0;
    char sDirectoryPathName[BUF_LEN_FOR_DIRECTORY];
    IniText IniTextFileHandle=0; //Handle for the text file.
    char sIniFilePathName[BUF_LEN_FOR_DIRECTORY];
    GetProjectDir(sDirectoryPathName);
    MakePathname(sDirectoryPathName,KEY_TEXT_FILE,sIniFilePathName);
    //Verify if there is enough memory
    nullChk(IniTextFileHandle=Ini_New( 0 ));
    //Verify if file is on disk
    error=FileExists(sIniFilePathName,0);
    if(error<VI_SUCCESS)
        //Terminate DAS3000.exe
        Terminate_Executable();
        return FAILURE;
    errChk(Ini_ReadFromFile (IniTextFileHandle,sIniFilePathName));
    //Conversion from pixels to degrees
    Conversion_Number(&iMultiplier);
    //Manipulation to get half of the frame
    iHalfOfFrameWidth= FrameSize.WidthCoordinate/2;
    iHalfOfFrameHeight= FrameSize.HeightCoordinate/2;
    //Math Expression:centroid value - centroid center
    //= offset value. (x=width,y=height)
    //These two expression below are calculating the x and y centroid offset.
    //Converting pixels to degrees
    dOffSetXposition=dSameXpositionValue-iHalfOfFrameWidth;
    dOffSetXposition=dOffSetXposition*iMultiplier;
    dOffSetYposition=dSameYpositionValue-iHalfOfFrameHeight;
    dOffSetYposition=dOffSetYposition*iMultiplier;
    //Gets the current user name
    iStatus = GetCurrentUser (sUsername, iBufSize, &uiNameSize);
    sprintf(szStringk,"Current User: %s",sUsername);
    texLogPdel(szStringk);
    LOG_FILE(szStringk);
    // Get operator ID
    if((texGetTPC ("OperatorID" ,g_sOperatorID,40))== FALSE)
        //Try again
        if( (texGetTPC ("OperatorID",g_sOperatorID, 40)) == FALSE )
            sprintf( szStringk,
                     "texGetTPC error - Skr Serial "
                     "Number cannot be retrieved '%s'",
                     g_sOperatorID );
            LOG_FILE( szStringk );
            strcpy( g_sOperatorID, "Unknown");
            LOG_FILE(g_sOperatorID);
    // Get UUT serial number
    if((texGetTPC ("UUTMSN" ,g_sSkrSerialNumberk,40))== FALSE)
        //Try Again
        if( (texGetTPC (UUT_MSN,g_sSkrSerialNumberk, 40)) == FALSE )
            sprintf( szStringk,
                     g_sSkrSerialNumberk );
            strcpy( g_sSkrSerialNumberk, "Unknown");
    sprintf(g_sXoffset,"%f", dOffSetXposition);
    sprintf(g_sYoffset,"%f", dOffSetYposition);
    //Storing the operator Id and seeker serial number in a text file
    //along with x and y offset position
    errChk(Ini_PutString(IniTextFileHandle, g_sOperatorID, "OperatorID",
              g_sOperatorID1));
    errChk(Ini_PutString(IniTextFileHandle, g_sSkrSerialNumberk,X_OFFSET_POS,
              g_sXoffset));
    errChk(Ini_PutString(IniTextFileHandle, g_sSkrSerialNumberk,Y_OFFSET_POS,
              g_sYoffset));
    Ini_WriteToFile(IniTextFileHandle, sIniFilePathName);
    Error:
    if(IniTextFileHandle)
       //Cleaning memory
       Ini_Dispose (IniTextFileHandle);
    if(error < VI_SUCCESS)
       sErrorMsg1 = GetGeneralErrorString (error);
       MessagePopup ("ERROR", sErrorMsg1);
    return error;
Message 46 of 63
(1,516 Views)
i think I found the problem, the logic suppose to be this way instead
    errChk(Ini_GetStringIntoBuffer (IniTextHandle, g_sSkrSerialNumberk, "OperatorID",
                          g_sOperatorID, BUF_LEN));
Message 47 of 63
(1,516 Views)
    int iMultiplier=0;
    int iBufSize=1000;
    int        error = 0;
    char *sErrorMsg1=0;
        return FAILURE;
    // Get operator ID
        //Try again
            sprintf( szStringk,
                     g_sOperatorID );
        //Try Again
            sprintf( szStringk,
    errChk(Ini_PutString(IniTextFileHandle, g_sSkrSerialNumberk, "OperatorID",
              g_sOperatorID));
              g_sXoffset));
              g_sYoffset));
    Error:
       //Cleaning memory
    return error;
Message 48 of 63
(1,517 Views)
so i just posted my logic of both the functions im using, I had to change my logic , because it was wrong in the first place, now let me step through
int Boresight_Command(double  *dAZposX,double *dELposY)
    int error=0;
    char *sErrorMsg1=0;
    char sAZposX[BUF_LEN]={0};
    char sELposY[BUF_LEN]={0};
    char sCrtCommand[BUF_LEN]={0};
    char sDirPath[BUF_LEN_FOR_DIRECTORY];
    IniText IniTextHandle=0; // Handle for the text file.
    char sPathName[BUF_LEN_FOR_DIRECTORY];
    GetProjectDir(sDirPath);
    MakePathname(sDirPath,KEY_TEXT_FILE,sPathName);
    nullChk(IniTextHandle=Ini_New (0));
    //Verify if file exist on disk
    error=FileExists(sPathName,0);
    if(error<=VI_SUCCESS)
       return FAILURE;
    errChk(Ini_ReadFromFile (IniTextHandle,sPathName));
    if(error == 0)
       goto Error;
    LOG_FILE(g_sOperatorID1);
    errChk(Ini_GetDouble(IniTextHandle,g_sSkrSerialNumberk,X_OFFSET_POS,
                         dAZposX));
    errChk(Ini_GetDouble(IniTextHandle,g_sSkrSerialNumberk,Y_OFFSET_POS,
                         dELposY));
    Fmt(sAZposX,"%f",*dAZposX);
    sprintf(sCrtCommand,"SERVO, WRITE, 098000034, %s",sAZposX);
    Send_SERVO_Command(sCrtCommand);
    Fmt(sELposY,"%f",*dELposY);
    sprintf(sCrtCommand,"SERVO, WRITE, 098000038, %s",sELposY);
    Error:
    if(IniTextHandle)
       //Cleaning memory
       Ini_Dispose (IniTextHandle);
    return error;
Message 49 of 63
(1,521 Views)
now when I step through it, my ini file look like this
[Unknown]
OperatorID = "Unknown"
X_BORESIGHT = "-639.940000"
Y_BORESIGHT = "-479.860000"
question if my ini file was like this below for the operator tag, dont ,y check suppose to fail  according to this check
    if(error == 0)
       goto Error;
[Unknown]
OperatorID = ""
Message 50 of 63
(1,522 Views)
