LabWindows/CVI
database connectivity
I am using Labview to connect to a Amazon Web Service Database which i have setup.
I have installed the ODBC drivers on Windows Machine and setup the connection in Administrative tools.
The connection tested out succesfully.
I have produced a vi which displays certain data.
The issue that i have is that i am wanting to sort out from that data certain data but for a particular site
I have a site drop down box on the vi and when i run the vi it displays the site name so i know i am connecting to the right area on the Database.
i then want to sort out from this site various bits of data and display them on the vi. The display is setup how a want it to look.
I have placed certain MySQL queries to request data that is in tables from the database.
Thesde command i have tested out on the AWS database and got the right information back.
For some reason labview is not displaying the data.
Pls could someone help and point me in the right direction.
(3,843 Views)
I can point you to the right board where to post: since you are using LabVIEW you should post your questions in their forum
(3,828 Views)
