LabWindows/CVI
datasocket 4.1 problems
Hi.
I'm using datasocket4.1 in my project.
And so, I try to connection PC to PC by cross cable.
But connection is very slow..
But Direct cable is good(hub)
Why? It is my problem.
And somtimes datasocket is stoped.
In this case, writer is good but reader is not response.
It is appear to same in your examples.
Why?
Answare me please.
regards.
(3,240 Views)
Jecki,
Could you provide some more specific details on what are you doing? What data type are you sending? how fast are you sending the data? are you using autoupdate?
DataSocket is based on TCP, so there could be colisions that cut down the max transmition speed, but there should not be a high drop when using a cross-cable.
The more details the better.
Juan Carlos
N.I.
(3,240 Views)
