LabWindows/CVI
datasocket 64 bit
I would like to build and run my CVI application as a 64 bit exe. However it uses datasockets, so I cannot. Are there any plans to support datasockets for a 64 bit application ??  If so, when ?? And if not, what are the alternatives ?? (I'm thinking replacing the datasocket connection with TCP).
(5,202 Views)
Hello hjb,
Currently, the DataSockets library is only compatible with 32 applications. However, you could use LabWindows/CVI TCP support library to develop your application. This library is compatible with both versions.
Carmen C.
(5,163 Views)
Hello hjb,
Carmen C.
(5,163 Views)
Although you could certainly use the TCP library, I believe that the Network Variable library is a much closer approximation to what you could do with DataSocket.
(5,130 Views)
