Hello Robert,
I started last weekend with datasocket, so don't be supprised if you get much better replies.
One of the functions I found is DS_SelectURL
This function gives a pop-up panel that enables you to browse in search of a server (computer) with the datasocket service (also called dss or datasocketserver). If you have a lot of computers in the network, this it not nice. However if you publish all the data on one computer, this computer itself is easily found.
After you have selected the computer/server, it shows the datasocket and OPC and other services. For the datasocket, it also shows the published datasocket items !
Succes, Jos
