LabWindows/CVI
dde with excel and CVI/LabWindows
I need to obtain the worksheet name on the Excel tab. The command for this "[GET.DOCUMENT(1,name)]". The macro indicates that Excel will return the name as a parameter (name) but it is not a variable in CVI, since it is inside the quotes. How do I make this command work from CVI.
(3,153 Views)
Hello
Check out the example included with CVI, it is located under CVI/Samples/DDE/ddedemo. It should explain how to retrieve data from excel.
You would probably need to use ClientDDERead, and set up the macro right.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,153 Views)
