LabWindows/CVI
debounce input from ports or lines
I would like to read the input of a specific line e.g. with the DAQ function ReadFromDigitalLine().
How can I make shure that the result is not a single peak?
Or, is the result of ReadFromDigitalLine() already debounced ?
(3,075 Views)
Hi Forelle,
What card are you using?
First of all you have to make sure the output from your device is debounced.
Regarding the card, in cards such as PCI-DIO-32HS and PCI-6534, in order to avoid ringing, you need to use proper cable such as SH-6868-D1 and also the appropriate termination scheme such as Schottky Diode termination etc.
You can find about the termination in the following link in the user manual of 653x.
Manual Page D-6 Onwards
Please do let me know if you have any questions.
Sincerely,
Sastry Vadlamani
(3,075 Views)
