LabWindows/CVI
debugging into a callback function
How can I debug into a callback function. when I set a breakpoint in the callback function, I never reach this breakpoint when I execute my programm. I want to see if the code in the callback function is ok.
regards samuel
(3,432 Views)
Hi Samuel!
   You can set breakpoints into callback functions, of course.  If during debug, you never reach the breakpoint, maybe your callback is never called! Check for this....
   In labWindows, differently from other IDEs (some Redmond IDE....), you can also put a breakpoint at the very beginning of it, that is:
   /*breakpoint here ----> */  int CVICALLBACK print (int panel, int control, int event,
                                                    void *callbackData, int eventData1, int eventData2)
                                                     if( event==EVENT_COMMIT ) {
                                                    SetWaitCursor (1);
                                                     etc....
so that when you press "print" button, you can see passed parameters!
Hope it helps!
graziano
(3,427 Views)
Samuel,
See my comments on your other post.
(3,405 Views)
