LabWindows/CVI
declaration of a 2 diumension array
  I'm tryning to decare an array of 18 line and 10 colomn
  char *stabMesures [19][10];
  i want that each cell have a maximum size
 what i can add to this declaration?
Many Thanks,
(4,536 Views)
What is an array of lines? Probably your line is a character array, so finally you will end up with a three-dimensional character array (18 lines each say 40 characters maximum times 10 columns). But then I do not understand what you call your cell...
(4,535 Views)
If each element of your array is to be a string with a fixed maximum length, you can define it as a 3-dimensional array:
#define MAX_LENGTH 7
char stabMeasures[18][10][MAX_LENGTH + 1];  // add 1 for the trailing null
If the elements will be different lengths, you can use dynamic allocation:
char* stabMeasures[18][10];
stabMeasures[0][0] = malloc(16 * sizeof(char));
sprintf(stabMeasures[0][0], "Element 0, 0");
stabMeasures[0][1] = malloc(24 * sizeof(char));
sprintf(stabMeasures[0][1], "Longer element 0, 1");
free(stabMeasures[0][0]);
free(stabMeasures[0][1]);
(4,531 Views)
