LabWindows/CVI
#define, doubles and typlib
I have developed an IVI-C driver in LabWindows 2009. I have the option to include the typlib in the Dll, selected. In the h file for the driver there are several #defines that have floating point values. Using these values in the CVI source code works just fine.
If I create a VB6 example and reference the Dll I can use these values but they are humungous values - obviously not correct. If I use Oleview and look at the typlib in the Dll the values are correct. If I use the Object browser in VB6 I can see that all the floating point #define values are equal to "blank" (nothing I guess).
Anybody have any idea what's going on?
I have looked at sveral of the class driver h files and notice for the #define declarations they are all integers but they are using a syntax like this:
#define xyz  (2L)   <- I assume L means long. Is there a similar syntax for doubles? I am just declaring my floating point values like so:
#define abc  0.1
(3,396 Views)
Yes, the "L" in that define makes the value a long integer. You can append an "F" to a number (no spaces something like: 2.0F) and that will force it to be a float but I don't recall (and have not been able to find online) any way to force the value to be a double.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(3,380 Views)
Now that I think about it (and I double checked it in a program) you can apply a type cast to a constant.
So try something like this:
#define DOUBLE_CONST {(double) 1234}
Maybe that will get you the result you want but I have no VB experience so I can't confirm that.
Martin Fredrickson
Test Engineer
Northrop Grumman
San Diego, CA 92128
(3,379 Views)
