LabWindows/CVI
define number of LF for FF
i'm using a receipt printer to log errors on an endless paper. The width of the paper is 40 characters. An error message has about 5 lines.
After each error message i want to advance the sheet a few lines so that the operator can tear it off. SetPrintAttribute(ATTR_EJECT_AFTER,1) advances the paper too much. How can i advance the sheet only a few lines?
Between every line the printer leaves a line blank as if PrintTextBuffer("aa") prints 80 characters. How can i avoid these blank lines?
I'm using Measurement Studio 6.0 on WindowsXP.
In windows i installed the printer as an "generic text only printer"
Greetings, Urs
(2,809 Views)
Hi Urs,
Unfortunately this does not seem to be a common application. I was not able to find any specific information about using a printer like yours with LabWindows/CVI.
While I am not able to test them with such a printer, there are two attributes available with SetPrintAttribute that may be useful.
The ATTR_PRINT_AREA_HEIGHT attribute will allow you to set the vertical size of the page to be printed, and ATTR_PRINT_AREA_WIDTH will allow you to set the length of a line. Setting these to appropriate values should allow the other functions you mentioned to behave as you expect. That is, lines will be printed as 40 characters, and the SetPrintAttribute(ATTR_EJECT_AFTER,1) will only eject the paper an amount that makes sense for your ATTR_PRINT_AREA_HEIGHT setting.
Scott Y
NI
(2,783 Views)
