LabWindows/CVI
dir size change
I need to monitor the size of a directory; as soon as the size
changes, a function has to start. I think it can be done with a timer;
is there a better way (something like a callback)?
(3,261 Views)
Hello
Check this example on the MSDN. You can use the Win32 SDK's that are installed with CVI for this.
Monitoring Changes in a Directory or Directory Tree
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,261 Views)
