LabWindows/CVI
directory popup
thnx wim
i want user to select only directory ...
i want to prevent user from selecting file...
(3,319 Views)
I believe what you want is to use the DirSelectPopup () function.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(3,300 Views)
If DirSelectPopup isn't quite what you want, an alternative approach is discussed here: http://forums.ni.com/ni/board/message?board.id=180&message.id=20141
--Ian
(3,255 Views)
