LabWindows/CVI
directory selection popup .... file selection shouldn't be allowed
only directory should be selected from a popup window...
no files should be allowed to select
(2,852 Views)
Even if you select a file in the dialog, the returned path will contain the folder in which the file is located.
But it is a good suggestion to maybe have an option in the function, if only directories are visible or all files. I will enter a suggestion for that in our database.
Thank you for the feedback!
(2,818 Views)
