LabWindows/CVI
disable test panels popup
Hello, could somebody please let me know if there is a way to disable the popup <<Test Panels: NI USB6211: "Dev2">>, at the moment when the DAQ card is connected to PC (Windows 7, LabWindows 10.0.1)?
On my other computer, the popup with Windows XP running LabWindows 8.0.1 was <<New Acquisition Device, What would you like to do?>>.... and there is a <<Take No Action>> choice where you could disable the popup for ever onward. Please see attached screen captures.
Could the former popup with Win7 be disabled in the MAX, or with a line of code regardless of OS and LabWindows version?
Many thanks!
(3,665 Views)
Windows 7 capture
(3,664 Views)
I am not sure about this particular device because I do not have a USB-DAQ handy. However, I know in the past for some of our other hardware I have used the Control Panel >> AutoPlay window to turn this off. At the bottom there is a section for Devices.
(3,649 Views)
I am having the same problem as Concordian (the MAX test panel always pops up when the DAQ USB6211 is plugged into a Windows 7 PC).  I've looked at trying to disable it in Control Panel > Hardware and Sound > AutoPlay, but the USB6211 never appears under the Devices section.  It is shown correctly on the Devices and Printers page.  Is there a way to disable this?
Thanks.
(3,590 Views)
(3,578 Views)
