LabWindows/CVI
disappearing graph
Hey guys,
I have a program that uses a 3D graph. Everything works properly until I get back to my Timer function. For some reason during the timer function my plot disappears. The axis are still set to the proper scaling, so it seems like it just becomes invisible. I have no functions in the timer that should affect the plot. I turn an LED on/ off and dim/undim a button or two. Any ideas? Thanks.
(3,528 Views)
In your timer callback, do you call ProcessDrawEvents? I am not familiar with the 3D graph, but it might autoupdate itself and get locked out if your program is in a callback routine...
(3,522 Views)
I was calling ProcessDrawEvent and I disabled it, but the graph still disappeared. I found out that i was unknowingly calling a function that cleared out the graph data. My bad. Thanks for your help though.
(3,520 Views)
