LabWindows/CVI
discardpanel
I am hoping someone can tell me what I am doing wrong. I am using newPanel to create a panel. Then use SetPanelAttribute, SetCtrlAttribute, and discardPanel in my panel function and it works fine by itself when I call it from TestStand 3.5. But when I run a wait popup in the next step it also discards the popup (the popup will flash up on the screen for 0.5 seconds or so). A example of the function is attached.
Thank You
Bill Ray
Message 1 of 1
(3,144 Views)
