LabWindows/CVI
display one text box on different panels
is there a way to duplicate a control on two different panels as i want to display a sample text box in two different panels , will wait for your reply
regards ahsan.
(4,402 Views)
This depends if you are talking about the UI editor in the IDE or if you want to achieve this at run time, i.e., programmatically. In the first case, copy and paste works, in the second, you can use the function DuplicateCtrl
(4,387 Views)
thanks alot
(4,301 Views)
