LabWindows/CVI
display unPrintable char ascii
hello,
i'm gething string from a bar-code, the bar code is program that at end of the string i'm puting a ctrl-g(^G) and enter.
CTRL-G in ascii table is 07. how can i check if i get the CTRL-G(^G) and the enter at the end of the string.?
regard's
eyal.
Message 1 of 9
(4,521 Views)
Hi!
   I suppose your program returns CHAR data type. If so, you only have to cast characters to integers, and display the integer number corrseponding to the char variable.
   char input;
   int myInt;
    input = getFromBarCode();
    myInt = (int)input;   //explicit cast, here, not compulsory...
   Otherways, you can get informations on char data type through some ansi C functions.  In ansi C library, select "character handling", and then "Character testing".  There you find some useful functions to tell you if you are getting a control char, and so on...
   Is quite silly as answer, but... I hope it helps! Have a nice day!
graziano
Message 2 of 9
(4,512 Views)
I presume you are just wanting to sanity check this once or twice vs. every instance.....
You can run thedebugger.
Break after receiving the data.  Highlight the variable and hit (shift + F7) to view the variable value.
That pops up a window with the value.  change the format (from the command toolbar) to hex and you will see all.
==>Scott
Message 3 of 9
(4,504 Views)
it's a dll for labview.
i'm reading the barcode into standart i/o.
but i'm still cant see the ascii chars.
here is my code :
int i,z;
   char j,ch=0;
    scanf("%s",input);
  for (i=0;i<strlen(input);i++)
       ch=input[i];
       z = (int)ch;
   if(z==7)
     printf("\n ctrl-g exsit\n");
     else
      printf("\nctrl-g not exsit\n");
   output=input;
Message 4 of 9
(4,500 Views)
Hi!
   Maybe the problem is scanf() function!   I think the problem is when you try to read the standard input and format it into a string (%s).  This way, the standard input is interpreted, and special characters cannot go into the string....  Moreover, a '\0' char is considered the end of the string, so you can't merge ascii data and strings.  (in LabVIEW, is not like this, you can wire a U8 array to a "byte array to string", and you get a string with special characters too!)
   You have to handle the input as an array of chars, and not put it into a string.
   Try something like:   read(stdin, input, number_of_Bytes_to_read);
   (or try with getchar() )
   I'm not shure about my post, just try and let me know if you solved!!  Have a nice day!
graziano
Message 5 of 9
(4,483 Views)
Hi, graziano
i try it in labview but it's not working there, becuse of that i'm trying to wirte a dll in cvi to solve the problem
if you have any vi just send it and i will chek it, and if it's work i'll will send you a beer :).
i will replce the scanf() and let you now if it's working.
try this link in labview forum :
regard's
eyal.
Message 6 of 9
(4,480 Views)
Hi Eyal!
   In LabVIEW  I have an array of unsigned 8 bit, I convert it to string, and send it via RS232, this works.  Maybe you have to do the opposite.  I suppose you may use VISA functions to read from a serial port (say...), and then you can convert the read string into U8 (I do this in the client application).
   Anyway, can you provide more details on:
    - how are you getting data (wich port.....);
    - what's the VI you use for read data;
   Let me know!
   I'm in Italy, and here it's 18.30! I'll be back tomorrow, and try to check....  have a good evening!
graziano
Message 7 of 9
(4,477 Views)
Hi  graziano,
I'm not using any visa, becuse the barcode is connected via the keybord input.
In labview the combination of CTRL+G[i think]  is shortcut to change working mode/run/edit
I'm using labview 7.1
regard's
eyal.
Message 8 of 9
(4,470 Views)
Hi!
   I understand! It's not easy, because (I suppose) the operating system filters the characters read from PS2 port, and re-maps it as char.   I'm not shure, but using read() c-function you should be able to acquire the right char (but sorry, I can't reproduceit....). I'm trying now, to test getchar(), I will let you know....
  Have a nice day!
graziano
Message 9 of 9
(4,457 Views)
