LabWindows/CVI
dll gdiplus cvi
In CVI, I want to include a dll from a scanner supplier. About the dll, you can take snapshots from the scanner, but the images are generated with the "gdiplus" - library.
Is it possible to bind in the dll in cvi??
(3,032 Views)
sure, if it is a Win32 Dll and you know about the functions´parameters
(so u need a header or documentation) you can just load it directly with "LoadLibrary"
which is a Windows SDK function, so u need the sdk installed.
Another way would be via a*.lib import Library. Then u use "LoadExternalModule"
It is all documented in the CVI Helpfile
Marco Brauner
NIG
(3,008 Views)
