LabWindows/CVI
dll messages popup
hi,
 i would like use user interface library in my dlls , my main aim is to use messages popup , but in a labview RT environnement , it doesn't work..
Can you give me more explanations.
TheGame
(2,886 Views)
RT is a headless non-interactive system. There really is no good reason to have a user interface downloaded on an RT enviornment. If you want to notify the system about some error or message, you can use the tcp libraries to communicate with a client across the network. Or you can print messages to the screen.
Include this function in your project
#include <windows.h>
typedef int (*RTPRINTF)(const char*);
int  CVIFUNC_C RTprintf(const char * debugstring)
   HINSTANCE hinstLib;
   RTPRINTF rtprintf = NULL;
   int returnresult = -1;
   hinstLib = LoadLibrary("msvcrt");
       // If the handle is valid, try to get the function address.
    if (hinstLib != NULL)
        rtprintf = (RTPRINTF) GetProcAddress(hinstLib, "printf");
        // If the function address is valid, call the function.
        if (NULL != rtprintf)
            returnresult= rtprintf(debugstring);
        // Free the DLL module.
        FreeLibrary(hinstLib);
    return returnresult;
Then if you want to use this instead of the default printf add the following to your C file
#ifdef _LINK_CVI_LVRT_
int  CVIFUNC_C RTprintf(const char *, ...);
#define printf RTprintf
#endif
This way, printf will print messages to the RT console.
Bilal Durrani
NI
(2,870 Views)
