LabWindows/CVI
driver interface could not locate or open the driver
I am trying to run the easyio tutorial with the at-mio-16e-10 using labwindows/cvi. i need to test the data acquisition function and i get a "noDriverError, The driver interface coudl not locate or open the driver". please help, this is my first time using data acquisition software. thank you.
(3,154 Views)
Hello
You might want to make sure you have installed the version of the NI-DAQ driver that supports your device, and have also installed CVI support from the driver. Here is a listing of all the boards and the drivers that support them.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,154 Views)
