LabWindows/CVI
dynamic memory is corrupt
I have two Ini_New(0) inside same funtion. i will dispose one Ini handler before i initiate another one. However, i received error "dynamic memory is corrupted" when i try to read .ini file using Ini handler created second time. I already dispose the first handler. I tried using different handler name but the same case appear. I need to read two Ini file, so please advice on how to solve the error or suggest me alternative way to do it.
thanks
(4,391 Views)
please ignore the previous post as i make mistake with my question
the actual problem is as below.
   IniFile = Ini_New(0);
   MakePathname(StrPrjDir,"Temp.ini",StrFilePath);
   if(Ini_ReadFromFile(IniFile,StrFilePath)==0);
    strcat(StrDFFileDir,"\\"); strcat(StrDFFileDir,StrDFFileName);
    fpFile = fopen (StrDFFileDir, "r");
    if(fpFile!=NULL)
     startRead = 1;
     do
        memset(StrBuffer, 0, 500);
        sdata = fgets(StrBuffer, 500, fpFile);
        if(!startRead)
            if(sdata!=NULL)
                    for(i=0;i<12;i++)
                   strcpy(SectionName,"Penang:"); strcat(SectionName,StrText[1]);
                   if(Ini_SectionExists(IniFile,SectionName))
                          if(dCompare2>dCompare)
                               for (i=0;i<11;i++)
                                       Ini_PutRawString(IniFile,SectionName,Items[i],StrText[i]);
                        else if(dCompare2==dCompare)
                                      for (i=0;i<11;i++)
                 else
                       for (i=0;i<11;i++)
I had encounter dynamic memory is corrupted when the last Ini_PutRawString is executed. Does this problem related to the fopen and Ini_New()? As i used both ini file and txt file in the above instruction.
Anyone, please advise.
(4,378 Views)
Hey popcorn,
I'm a bit confused now that you've asked two different questions.  What is it exactly that you're trying to accomplish - reading from two INI files at the same time?
This help article describes the reasons why you'll receive a "Dynamic Memory is Corrupt" error message.
Perhaps it would be best to post a small example that I can run that demonstrates this error?  The code you posted earlier uses a lot of variables and logic that I believe is not pertinent to replicating the issue.  Could you create a small example and post the file to this thread so that I can replicate this on my machine?
Derrick S.
Product Manager
NI DIAdem
(4,325 Views)
I tried to generate a sample code for you to test. I create simple timer loop with Ini_ReadFromFile(). When i run on that sample code, no msg of dynamic memory is corrupt occur. Then i found out that i change StrDFFileName somewhere inside timer loop that caused dynamic memory error when the timer loop run second time.
Thanks alot in helping me find the problem.
(4,303 Views)
