LabWindows/CVI
dynamic textbox "indicator" to "hot"
How do I programatically toggle (via checkbox) a textbox control mode attribute between "indicator" and "hot"?
I am using LabWindows 5.01 on WinNT.
(2,883 Views)
Use the function SetCtrlAttribute to set the attribute ATTR_CTRL_MODE to either VAL_INDICATOR or VAL_HOT.
For example,
SetCtrlAttribute (hMyPanel, MYPANEL_MYTEXTBOX,ATTR_CTRL_MODE, VAL_INDICATOR);
See the function help in the fuction panel for SetCtrlAttribute.
(2,883 Views)
