LabWindows/CVI
easytab
Is it possible to use EasyTab to open sub-panels in different .UIR file ( Labwindows/CVI 6.0) ?
(3,426 Views)
Yes, you can load any panels into the easy tabs. You are probably using EasyTab_LoadPanels. You will want to use EasyTab_AddPanels instead. First, load the different panels from the UIR files and get handles for them. Then call EasyTab_AddPanels to the add the panel handles as tabbed panels.
Best Regards,
Chris Matthews
(3,426 Views)
