LabWindows/CVI
edit controls
CVI2013 does not appear to allow edits of multiple controls on the user interface.
The user interface editor in earlier versions would allow text format and styles to be set for all controls of the same type, selecting multiple controls by holding the shift key and left click to select, followed by a right click and then "Edit Controls" from the presented drop down, this all appears similar in 2013 but the "Control Text - Text Style" and "Label Appearnce - (....)" no longer work.
Is there a reason why this useful feature has been removed?
(4,720 Views)
Hello John,
This is a known issue. It appeared in CVI 2012 and will be corrected in the next release.
Constanin.
(4,711 Views)
