LabWindows/CVI
edit ini files in CVI
when I try to edit a ".ini" text file in the LabWindows/CVI editor (File->Open->Text(*.ini) etc.) I get the error: "Cannot open binary files as text files", although the file I try to open is indeed a text file editable with Notepad. How can I inform the CVI editor that it is NOT a binary file ?
Thanks a lot,
Marco
ElbaTech srl
Italy
(3,611 Views)
Just a guess, but this is probably because the text file is encoded using Unicode, which nopepad understands but CVI does not. Load the file in notepad and try to 'Save As...' and select ANSI encoding.
Hope this helps,
-alex
(3,585 Views)
Great Alex,
this was the problem !
Thanks a lot,
Marco
(3,574 Views)
