LabWindows/CVI
eliminating repetitive numbers
is there a way to transform a 1D array from, let s say, (0,0,1,1,3,4,4,4,4,5) to (0,1,3,4,5)
(2,818 Views)
Good question. I don't know of any fast method or built-in function.
When I had to do the same, I processed the array in a loop and copyed items in a new array only if different from the preceding one. If needed, I sorted the array before processing.
Let's see if anyone knows a faster and more efficient way...
Roberto
(2,818 Views)
