LabWindows/CVI
embedding the UIR files in Lab Windows/CVI 6.0
how do you embed the UIR files in the executable in Lab Windows/CVI 6.0. I am having to copy all the UIR files to each computer i put the .exe on. Is there a way to embed them with the .exe so you do not have to worry with it?
(3,269 Views)
Hello
You can use the UI to Code converter tool to make the UIR file into a C file. This wa, you wont have to distribute the UIR file every time with your exe. You can get to this tool in the UI editor under the Tools options
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,269 Views)
that was exactly what i was looking for thank you!!!!
(3,269 Views)
