LabWindows/CVI
error: Undefined symbol '___ImageBase' referenced in "c:\program files (x86)\national instruments\cvi2017\bin\msvc\cvistart.lib".
Dear All,
I am always getting this link error.
I suspect that the project I am trying to build was made in a previous CVI version.
Please help
Francesco
(3,901 Views)
(3,883 Views)
Thanks for your reply.
Can be a windows releted problem? one collegue has windows 7 and it seems to compile and build fine but I have windows 10.
Francesco
(3,879 Views)
I have made some more experiments.
I started from the example here: https://www.ni.com/en/support/documentation/supplemental/09/calling-a-dll-in-labwindows--cvi---expli...
It works fine.
Then I added the .lib and .h that I need to use and added some simple code just to open an USB communication.
I get the same error I get in my project.
If I comment the line with hid_open then no problem.
I am attaching the modified example in case of need.
Francesco
(3,870 Views)
Update: in CVI2010 the project can be successfully compiled and built. In CVI2017 not.
So maybe there is some kind of issue with 32-bit DLL managing in CVI2017.
(3,846 Views)
