LabWindows/CVI
error: Undefined symbol '__UPLibBreakpointWithElabUtf8' referenced in "c:\Program Files (x86)\National Instruments\Shared\CVI\Bin\msvc\visa.lib".
I get the linker error I placed in the subject header when I compile my program in debug configuration.  If I compile it in release config I get no linker errors.
Im running CVI V17 , and I haven't changed any compiler settings.  Do I need to update my visa.lib file ?
Regards, Ross
(2,441 Views)
I "fixed" this error by selecting options>build options>debugging options=no run time checking.
I still haven't found the root cause of the error.  I suspect a VISA dll conflict/version issue
(2,387 Views)
