LabWindows/CVI
error cvirte 7.1
Hi guys,
We've had the customer uninstall, manually remove all CVI files, and reinstall and he's still seeing the error.  I'm going to send him a new burn to see if that clears it up.  I've also had him check the DEP and he has it to the minimal setting.
Judy
Message 11 of 12
(738 Views)
Judy -
I would consider giving the customer a debug build, you can rename the executable to eliminate the "dbg" suffix.  Then, when the error occurs, if it's in the developer written CVI code, the customer should see a popup identifying the error and giving a module and line number reference to the origin.
As far as VirtualAlloc, I do know the heap allocation methods have undergone change / revision over the years - I recall we had an allocation of some kind that failed on XP Pro so I found sample Win32 code that used a LocalHeapAlloc of some kind instead of GlobalHeapAlloc I think it was and the problem went away.
This may be as simple as the application overflowing the buffer allocated by VirtualAlloc.
Menchar
Message 12 of 12
(728 Views)
