LabWindows/CVI
error: dbgasctime not found in cvirte.dll
When I try to debug my cvi dll, I got this error in LabVIEW.
Anyone run into this before?
George Zou
(4,175 Views)
Accepted by topic author zou
Is the system where you created the DLL the same where you are calling it? This kind of error reminds me of a problem in the run-time module: can it be that the machine where you are running the DLL has an older run-time than the system where you created it?
(4,158 Views)
Thanks for reply.
The test PC is the same as the develop PC.  It got upgraded to 9.1.1 a few monthes ago.  The cvirte.dll in the system folder is 9.1.1, 2010-06-30, 4,959KB.
And there is only one cvirte.dll on C: drive.
George Zou
(4,134 Views)
Oops!
I searched again on the C: drive, and found an old copy of cvirte.dll.
Removed it.  Now I can debug.
Many thanks.
George Zou
(4,129 Views)
