LabWindows/CVI
error reading 'strcmp(a,b)'
I am attempting to rebuild a program that ran on a Windows 7 machine a few years ago.  I am currently using CVI 2019 on a Windows 10 machine.  Whenever I attempt to build the program (or even just compile a file in the project), I receive the following error message: "1,1 error: error reading 'strcmp(a,b)'.  To demonstrate the problem, I have created a very simple program that displays the same behavior.  I have rebuilt a couple of other programs on my computer today without issue and it isn't obvious to me what is different about the two that generate the error.
(2,758 Views)
Accepted by topic author Double_D
You seem to have a Compiler Define statement that is causing that error.
Remove the statement from Options->Build Options in the Compiler Defines field, and you should be able to build and run just fine.
(2,706 Views)
Thanks for the tip.  I looked at the Build Options setting, but apparently did so too hastily.  The old project I was trying to build had this compiler define and it was then copied over when I created the new project.  Once I removed it, the new project was successfully built.
(2,701 Views)
