LabWindows/CVI
error when declaring a variable named "interface" after including cvixml.h
after having included "cvixml.h" in my file, the compiler stops with 3 errors each time i declare a variable named "interface". errors are:
- missing struct tag
- invalid type specification
- warning:  empty declaration
when i do not include "cvixml.h", the error does not appear. and i can't find a "struct interface" declared anywhere in CVI's headers. i suppose it has something to do with cvixml using msxml COM object, thus "enabling" an "feature" which allows to declare COM interfaces... but this is a supposition...
is this problem normal ? what happens ? how can i name my (local) variable "interface" ?
(3,411 Views)
interface is #defined as struct in objbase.h and used by msxml.h
You can #undef interface after having included <cvixml.h>
I hope this helps,
Nicolas
(3,406 Views)
it helps a lot ! that works, thank you !
(3,400 Views)
